The KLN 94 does not have ARINC-429 output, only RS232 and analog. I have confirmation from another user that the RS232 from the KLN 94 will successfully provide track, groundspeed, distance from course centerline, etc. i.e. enough to draw the HSI/CDI.
Via the HS-34, do you think it would be possible to also use the analog resolver inputs? Can the configurations be set to accept RS232 input and simultaneously analog resolver inputs?
If so, the KLN-94 has the following OBS connections:
OBS OUT
OBS SIN
OBS COS
OBS RETURN
Can you correlate these to the Resolver C,G,H,D,E,F connections on the HS-34
Thanks you.
