Seattle Avionics Map Issue
jacktunnell
Layout: 10"Skyview PFD and 10" Skyview MFD. Seattle Avionics subscription. Two SanDisk mini thumb drives.
Issue: MFD maps will not acknowledge VFR in LAYERS using either thumb drive. PFD will load VFR maps in LAYERS using either thumb drive. MFD will not initialize with either thumb drives plugged in. MFD will download updates from Dynon with no issues.
What I've done so far: Deleted all Chartdata from each thumb drive before loading the new downloads and retry with same results.
Next step: :( :'( :-/ Any ideas?
mrdaud
Also having issues. Tried for 4 days to download files manually to my Mac, but finally gave up and borrowed a PC to use the SA download manager. I see airpot diagrams now, but nothing in LAYERS, no VFR maps. I have retried the downloads several times. :(
jack - When you plug the USB drive into the display that can't see the files, what do you see under SETUP MENU > LOCAL DISPLAY SETUP > INSTALLED DATABASES? Also under SETUP MENU > LOCAL DISPLAY SETUP > INSTALLED DATABASES > MAP?
Same questions for you Dave...
