Sensor data not output on log
Doug1
Hi
All
I have recently added a sensor to C37 P10 (General Input 6)
The input is designed to show Generator output current on a Rotax 912ULS and works great,
with the displayed current widget working perfectly.
But when I export user data logs and inspect the log, the column for this sensor remains with the title "General Input 6" with no data recorded. It is as if the sensor input hasn't been mapped, even though it has and the sensor display works.
Other sensors I have added have appeared in the log with their correct name and logged data
Anyone know what could cause this?
Doug
Doug1
Hi
Dynon Admin
Can you throw any light on this issue?
Is there anything I can try?
Doug
Don't have an obvious answer on this one. Can you send a sample of the log, along with a copy of your configuration files, to support at dynonavionics dot com so that we can take a closer look?
Doug1
Have emailed a sample of the log and config files to support@dynonavionics.com
Doug
Doug1
Hi
Thanks for all the help
Look forward to a fix in 15.4.0
Doug
