Seperate trim displays
skysailor
I have electric pitch trim with a position sensor routed to display on the D1000. This works just fine. The issue I have is that the widget to display this is designed to display 2 axis trim. I do not have roll trim. The current trim widget shows the pitch trim position but there is a large "CAL?" displayed for the roll. Can I get a widget which only displays pitch trim or at least remove the CAL? from the trim widget?
Sky sailor
Page 7-63 (rev O) covers that however you can remove the widget & then only add the Pitch Trim one, I think.
I'll look at one tomorrow to confirm & will PM you :)
Remove the trim axes that you're not using from the EMS pin mapping setup. Then the widget will fix itself.
