I am installing a roll servo into my Zenith 601XL. Per the application guide an SV32 servo was recommended. I have installed, config'd and calibrated the new software and servo. I initially mounted the rod end on the outermost servo arm location. When I perfomed the servo test, the servo jittered and clicked, but did not move the control surface. Assuming there was not enough torque power, I then put the rod end on the inner most arm location. Then it was able to move to the right a little bit before clicking over and stopping. It was, although, able to move to the left it's full intended travel. Does this mean that the SV32 servo is not strong enough for my application?? If so, is there a way I swap for the next stronger servo?
Thanks,
Dave Gallagher 601XL
Thanks,
