rogersmart
- Joined
- Aug 4, 2008
- Messages
- 109
I have purchased the pitch and roll servos and installation kits for the RV8 I am building. I am patiently waiting for the new generation system. However I want to install wiring to each servo before I move forward with closing the wing and aft fuselage.
I have reviewed the current wiring overview that was sent with each servo. From previous post I gather the wiring may be different with the new generation system and the White/Green and White/Blue wires will be used.
Please honor my patronage of Dynon and help me move forward by answering the following questions.
1. I assume the Red wire (Power) sized for 2 amps and to a breaker wired as shown in overview. The Black (Ground) also sized for 2 amps can be grounded to the airframe at the servo. Are these assumptions correct?
2. Green and Blue (Data) wires can be 20 or 22 AGW and a twisted pair since they are data wires. Are these assumptions correct?
3. The Yellow (disconnect) wire can be 20 or 22 AGW as virtually no current is present. Is this assumption correct?
4. The new generation data bus wires will be a similar in that it is 2 wire and data wires from any component in the system can tap into data wires from another component, ie they do not have to run back to a specific module or screen. Are these assumptions correct?
5. White/Green and White/Blue wires. My main concern is what size and type of wire to use and where will it be run. What will the function of the wires be. I’m not looking for corporate secrets just want to move forward with my build. If it is a trim motor adjustment the wire would be run to a different location than another purpose. Please provide what info you can for the sole purpose of running wire.
Thanks in advance for your help.
