Single servo installation
jeffa
Lewisville, TX
I didn't clearly see an answer in the Skyview install manual, but is it acceptable to have only one servo installed in the system (e.g. just a pitch servo for altitude hold)?
I realize this is not using all the functionality of the system, but due to budget and other constraints, I was just going to install one servo for now.  Just want to verify that it will work and won't cause any problems or crazy messages from the Skyview.  Thanks.
Should not be a problem - the system will only work with what is listed in the configuration menu & after you've done the calibration. ;) When you add other items then reconfigure etc.
