Skyview 15 no W&B
tomkk
RV-12 ELSA
Port Orange, Fl
Loaded v15 in my D1000T and have just started using it. Looks good so far but I can't find the Weight & Balance page. I think it's on the Tools page but the button labels along the bottom are:
BACK/TIMER/blank/blank/MAINT LOG/ blank/blank/NO MSG
What am I doing wrong?
vlittle
Same with me on D1000. Also, Maintenance log has no way to input data. If I hit the cursor button to the left, some weird window pops up.
Vern
Langdon
McLaren Vale SA Australia
I think you'll find it under system setup then aircraft information. Once setup it will become visible in the tools tab.
I was given wrong advice from Dynon regarding the units, although it works with any units, it will label them with lbs & in which is not acceptable if using metric as it could lead to incorrect information input. I haven't tried using the maintenance log but I wouldn't be surprised if its input was to be found in a similar spot.
Langdon
Vern
I have just found this on mine, it is in the Aircraft Information page of the System Setup menu.
preid
SoCal
I know there is a .csv for checklist, is there a file for W&B and maintenance logs? It sure would be easier to type all the information on a keyboard and import the file into the skyview than trying to do this one line at a time.
Thx
Langdon
Thx
It doesn't take much time to input, took more to collect the information.
preid
SoCal
Support;
Any update on installation manual? Im assuming all the setups and other information needed to maximize the v15 features are covered in that manual?
Thx!
