SkyView 5.0 Released!
I just wanted to share that Dynon released SkyView Software Version 5.0 today. This release is a big one: It adds ADS-B weather, traffic, and TFRs capability to US-based SkyView systems when paired with the SV-ADSB-470 module ($995) that we released last week.
This also means that when paired with an SV-XPNDR-26X transponder, Dynon has the only widely available and affordable ADS-B solution for homebuilts and LSA aircraft that incorporates an ADS-B Out transmission. This is important, as the transponder-based ADS-B Out transmission wakes up the ADS-B ground stations and causes them to send a traffic portrait that includes all known ADS-B targets around the SkyView-equipped aircraft.
SkyView 5.0 can be found on from our website.
Here are a couple of images of how weather looks on SkyView 5.0:
Incidentally, I know you guys love screenshots. Here are the 3 different ways you'll be able to display weather/terrain in SkyView. It's a simple 3-way toggle switch (button 6, as seen in the screenshots):
Terrain Only:
Terrain/Weather (terrain muted):
Weather only (terrain off):
Edwardoc
Colorado
The latest data base download is titled FAA 5.0 1213. I have not updated to 5.0 as of yet. Is this the correct update for 4.0 systems? :)
aerofurb
Apologies for not spotting the answer if it's out there - will v4 PocketFMS still work okay with SkyView v5.0?
Yes, although you won't get the improved European support such as showing CTA's and TIZ/TIA airspace more correctly.
aerofurb
Thanks for the quick reply.
No doubt there will be a v5.0 PocketFMS along soon! :)
mikehoover
Is is okay to install 5.0 even though I do not yet have the ADSB unit installed?
Yes, I installed mine with the updates and still have ADSB sitting in a box
Thanks! Unfortunately, my ADSB is still in a box far far away from me. Hope to inform the vendor soon that one of them is mine. :)
In the 5.0 release:
Improved: Fuel quantity gauges can now use arc, bar, and contact widget styles
the arcs behave like a normal arc and don't show the top of the tank empty like the fuel bar. Is there a way to make the top of the tank dynamically show black like the fuel bar?
Garrett
Tampa Fl
The traffic and weather work excellent here in Florida. The traffic is even better than any TCAS system I have ever used. :)
