Bubblehead
- Joined
- Oct 3, 2011
- Messages
- 37
I had the stuck "Screenshot in Progress" message Saturday with a SanDisk 16 gb thumb drive inserted. I finally rebooted.
I also had two screen problems.
1) I de-selected PFD and MAP to look at all the engine instrument readings and the left side of the screen, where I usually have PFD, had a green tint to it. I rebooted SkyView and the tint went away.
2) later the same day, after flying, I had SkyView running on the backup battery adjusting settings and the screen went blank. I turned the Master Switch on and off to cycle power but nothing changed. I could hear the fan running so I knew SkyView was still on. I finally disconnected the battery, reconnected it and booted SkyView up. It came up fine and shutdown fine and did not freeze while I was in setup mode.
I downloaded the diagnostic file and will send it to you if would help.
I was hoping for a response from Dynon Support on the other two screen problems I had. I am most concerned about the second one. I would hate for that to happen during flight at an inopportune time.
