RVDan
I was flying with the AP engaged and the FD roll mode in Nav, tracking the GPS-250 flight plan. The pitch mode was set to vertical speed (-500FPM) as I was descending from my cruise altitude. The altitude preselect was set about 2500 ft below my present altitude. Speed hit the max limit (envelope protection) for pitch (ASPD HIGH annunciation) and the aircraft pitched up maybe 10 degrees, then pitched down to somewhere around -10 degrees with a max vertical speed of about -1200FPM before I intervened by reducing power. It then pitched up again overshooting less and eventually settled on the proper vertical speed. It had perhaps 3 overshoots before getting back to the set vertical speed. This was in smooth air.
Since I had plenty of altitude and safety wasn't an immediate concern, I let the AP go to see how it handled the situation.
The AP has been functioning properly other wise, but this was the first time I hit the max speed protection.
I was wondering if I should expect that behavior when hitting the max speed protection? The aircraft is a RV-6A. This was with V14 SW. This was in the last 30 minutes of flight, so I should be able to download the diagnostics file if you want it.
