Skyview Audio not working with SL 15 Audio panel
rlallen1
Hello.... I am troubleshooting an issue here. My audio on skyview worked fine with my previous set up so I know the new issue is due to wiring of my newly installed SL 15 Audio panel. I connected the 2 audio out pins from the Skyview to PIN T bottom adapter on the SL 15 Audio panel. Per the manual, this pin is an unswitched audio input pin. So far I cannot seem to get any messages from the skyview. I was hoping someone familiar with the 2 could confirm if this should work or not. My alternative is to unpin the pin T and use the pin for audio in of the ADF on the audio panel (since I don't have an ADF).
Ryan
I had that combination but changed to the PMA 7000 (SL15 was PMA6000) & it all works.  I'd suggest a recheck of the bottom connector if you haven't changed anything else.  Did you combine L & Right channels ?  :)
I use masking tape & identify each number & letter due to the pin markings being so hard to read on the connectors, reduces the risk of mislocating a connection - maybe that's what happened ?
rlallen1
Ok. Yes I did combine the left and right from the skyview. I will recheck my pin locations to make sure I didn't miss it.
rlallen1
Checked the pin placements tonight. Turns out I mislocated pin T for pin16. I placed the pin into T and I have audio from skyview. Yippy
