Skyview + AV-30-E + GTN650
pazmanyflyer
Litchfield Park, AZ
Anyone have a wiring diagram for the GTN650 + AV30E (with AV-HSI) + Skyview? I'm currently planning an IFR upgrade to my Skyview equipped RV-7. I've drawn up a wiring diagram but I'd like to have a look at someone else's working example to compare them. I think I have the Skyview 429 wiring figured out. I'm not certain about the ARINC AV-HSI wiring TO/FROM the 650. I'm also not sure if I'm supposed to split the 650 VOR/ILS OUT to both SKYVIEW and AV30. I don't see seperate VOR/ILS OUT from the 650 manual to do so.
Best regards,
Carlos Hernandez
RV-7 in Arizona
I have a GTN625 in my dual HDX setup. I have connections to the ARINC and the transponder. No AV-30 here. What do you need to know? I have a wiring diagram. It's about the size of a table cloth.
After after DEEP dive into the internet rabbit hole last night I found an example that is very close to what I wanted to do. The example was the 650 + G5. Short story: I'll use separate 650 arinc outputs from the 650 to the the Skyview and AV-HSI. This allows me to set up each individually per manf. instructions. I'll have to parallel the arinc 429 VOR/ILS (VLOC) outputs from the 650 to both the Skyview and the AV-HSI. The AV-HSI would not be able to send any data back to the 650 since it can only accept a single EFIS input. That inout will be my Skyview. Time to make the harness.
I have my AV30 completely isolated except for a serial line to my 440. This doesn't give me GS or anything I get through the 429, but it does give me flight plan and nav.
the 440 is on the 429 to the SV.
