FreddytheK
Looking for suggestions to solve glitch...what follows is email thread w/ Dynon Tech Support and my response (indented) to their suggestions:
Might this “FAULT - DATA 2 PAIR (PINS 4 & 8)” be traced to a pair of wires coming from the DSub37 harness?…If so, can you identify which wires they would be so I can trace them?
Gentlepeople…please read indented comments below…Fred
On Jun 9, 2017, at 4:58 PM, Dynon General Support <info@dynonavionics.com> wrote:
Here are a couple suggestions:
1. It is possible that the Com Panel is the culprit. Try only hooking up the ADAHRS network cable and disconnect the cable going to the Com Panel.
I have disconnected both D9 plugs from the D700 display…(one went to my SV-HUB, and the other went direct to the COM).
2. Remove the ADAHRS and try connecting it to the display with another cable.
I have disconnected the ADAHRS cable from the ADAHRS module.
I have now connected the ADAHRS module direct to the D700 display using the Dynon-provided service test cable.
The screen shot below is what I now see on the D700 display.
I note that the yellow caution for the DATA 2 PAIR (PINS 4 & 8) has now moved from the ADAHRS to the SV-DISPLAY.
After seeing this display, I disconnected the Dynon-provided service test cable from the D700 and reconnected it to the other D9 receptacle, went back to CONFIGURE, hit DETECT, and the same yellow caution appeared just below the line item for the SV-D700.
From this, I would infer that the problem of the DATA 2 PAIR does not lie in the ADAHRS module or cable.
Please advise…F.
If you still have problems then I think the ADAHRS might have an internal problem with that DSAB port.
Regards,
screenshot-N19417XS- (shows yellow prompt below "SV DISPLAY" stating "SV network connection fault - data 2 pair (pins 4 & 8)
Please advise…F.
Regards,
