Skyview & Garmin 430W nav problem.
rfazio1951
I've been flying for a few years with the 430W & Skyview combo. Recently I'm getting a problem with selecting a VOR on the 430. I can't get any indication on the skyview's HSI. GPS works perfectly and strangely if I select an ILS approach I get all indications perfectly. With a VOR it's like the VOR is dead. So thinking it was I've been trying a few. I also have a Val Nav 2000 and that receives the VORs fine. Does the 430 put out the signals to the Skyview on the same channels for VORs and ILS? I think so. I have the Arinc 429 installed, but I know I ran some serial wires between the 430 and skyview.
There are two wires specifically for the VOR/ILS data from the 430W to the 429 ARINC. Channel A goes from pin 24 of the 4006 connector on the 430 to pin 22 on the ARINC, and channel B goes from pin 23 of the 4006 connector on the 430 to pin 10 on the ARINC. I know that the ILS data goes on channel B, I had a broken wire on that pin a while back that stopped my ILS function from displaying - but I don't know if the VOR data is on the same channel, or on channel A.
The GPS data (both directions) is carried on a separate set of connections and will display just fine regardless of the condition of the VOR/ILS side.
rfazio1951
Good idea, Airguy. I'll see if I'm getting the identifier. I did try swapping the antennas. I switched between the second NAV and the Garmin. Same exact thing so I don't think it's antenna related. Thanks guys, I'm going to do more detective work this week.
