mikehoover
- Joined
- Sep 12, 2005
- Messages
- 63
If I have my Garmin 496 data out wired to a Skyview serial port 3 RX, as well as having the Dynon GPS wire to Serial port 5, and then wire Skyview serial port 3 TX to the Trutrak ADI II autopilot, will the autopilot run off the 496 if I switch gps sources on the Skyview from POS 1 to GPS 1 (assuming they are set up in Skyview that way.)
I am wondering if it would be a good idea to have a panel switch to switch gps sources to the autopilot. If the Skyview were to go blank for some reason, would I not be able to use the autopilot if wired like I mention in the above paragraph?
