Skyview Installation Guides
pacecapt
Pace, Florida
Is there somewhere on the Dynon site to download a copy of the older Skyview Installation Guides? Reason, my Dynon System has the EMS 220 and all the new guides refer to the EMS 221. l have a non-CANBUS UL Power engine with EMS 220 and the installation and configuration section of the online guide refers to the "with CAN Bus" table. Unless they are identical? Also some QC needs to done as Table 48 for the UL Power Engine makes reference to parts that are used on a ROTAX (Pin 15)...
Stevec
The current installation guide AO refers to both the EMS220 / 221.
Although the section for the UL Power with CAN Bus on page 7-36 says "Table 48 below", it's a misprint. The table below is Table 51, and the table is properly labeled as such. Table 48 on page 7-31 is for the Rotax 912 ULS.
The Honeywell and Rotax oil pressure sensors are functionally identical, and the Rotax brand is not limited to use on Rotax engines. That's why they're listed in that table. The Honeywell sensor is reportedly no longer available. Settings are discussed here:
There's also a long running thread on the characteristics of the sensor here:
However, those tables are labeled as "Suggested." If you look at Table 28, Dynon recommends Kavlico sensors for the UL Power without CAN Bus.
