SkyView Network Wiring Hub
vlittle
This is a heads up to list members on a new product we are just introducing:  a five channel SVN wiring hub.
Earlier this year, we intro'd a wiring hub for managing the RS-232 and related signals from Dynon SkyView EFIS systems (called the AXIS-15A).  See the thread http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1290017431/14#14.
Now, we are about to introduce a similar function for the SVN.  The AXIS-9A will take a single SVN connection and expand it into four SVN connections (a total of five connectors).  This replaces three SVN Splitters at a lower cost, weighs less and occupies less space.
It's ideal for behind the panel connections (2xSV, EMS, ARINC, Autopilot....) or it can be put elsewhere in the aircraft where multiple splitters would normally be required.
More information is forthcoming.  In the meantime, you can contact me vern_little -the at sign- vx-aviation.com for more information.
Vern.
Proud to support Dynon products!
vlittle
And to add insult to injury, we have just release two other wiring hubs in addition to the AXIS-9A (above) and the AXIS-15A (RS-232 thread).
They are the AXIS-25A and GBX-25A.  The AXIS-25A is a 25-wire, five connector hub, while the GBX-25A is a 25-wire ground (or power) distribution block.
See pic below, more info at www.vx-aviation.com.
Now there's no excuse for that rats' nest of wiring behind your panel!
Vern Little
Vx Aviation
kziygz5bwg0
UK
lOOKES Very interesting  just woundering if you will be enclosing the boardes in a case to protect them     :)
vlittle
The boards won't have enclosures. This reduces size, weight and cost (especially cost). If mounted in an exposed location, you may fabricate an aluminum shroud if you wish, but most installations will be well protected behind an instrument panel.
If you want fully enclosed versions, you can use the hubs from Approach Fast Stack. They start at around $500, plus the cost of customized wiring harnesses.
Thanks, Vern
kziygz5bwg0
UK
Thanks Vern still very interested and and when I start assembling my panel probaly will purchace the necessary boards
Thanks Chris
