DrewSwenson
- Joined
- Dec 29, 2009
- Messages
- 47
Just happened to me yesterday---most likely my fault----but looking for help. Skyview is installed in my Cozy MKIV. ILS approach in the driving rain into KLAF---all was well. Airplane is not completely leak proof and I had left off the glider tape that seals the back edge of the canard. End result---while parked at KLAF----it is possible (but not probable) that the AHRS unit got wet up in the nose------it is likely that the backup battery got wet (near the seam with no glider tape)-----and 50/50 chance that the back of the skyview screen may have gotten some moisture on it.
Took off into the goo when the screen went black. Was on stby instruments for remainder of flight. Multiple resets of the breaker switch did not bring it back alive. 1/2/5 did not bring it back. Turned the heater on to help dry it out---if that was the issue----did not work.
After landing------pulled the access panel off----all dry---no wetness anywhere----but my heating over the 3.5 hour flight may have gotten rid of the evidence. With master and dynon switch off----I pulled the big dynon connector off and felt around it----felt dry----plugged it back in----and the display fired up on the backup battery.
Backup battery is low (may have been trying to power the display during flight??). While on the ground, could not consistantly turn on the dynon with ship's power unless I unplugged the backup battery.
I can fix the plane so that none of the components get wet again. But the backup battery connected/not connected issue seems strange---and still scratching my head-----but maybe this is the unit just still trying to dry off?
