Stubbleducker
- Joined
- Jul 2, 2010
- Messages
- 4
Howdy, folks! First post here (but lurked for a while). Just completed helping a friend build an AirCam with a Skyview 700. Started everything last night for the first time and 98% worked the first time!!!
However, a couple issues with the Skyview remain. Have searched through the archives and the wiki and despite all the wealth of information haven't seen exactly what I'm looking for...
Relavent avionics: Skyview 700, Garmin TXP-330, Garmin SL-40 com, and Garmin 396 GPS, AHARS (but no SV-250 GPS or EMS - not available for dual engines yet).
1) When powering up the Skyview, about every other time half the screen remains dark and half has multi-color lines like the old TV test pattern. Cycling the avionics master typically will fix the problem, but don't like the idea of cycling the avionics master twice every startup sequence as a normal thing. System voltage is normal - 11.75 volts or 13.75 when engines running.
2) GPS not displaying on Skyview. From the wiki I found that you can't have both Garmin RS-232 outputs hooked up, so that's part of the problem. It's setup in the Skyview as "Garmin 396", have tried setting to "POS1" and "GPS 1" but neither worked. Will also verify that the 396 itself has it's output settings set up to send correctly (found that online this morning as well).
3) TXP-330 Transponder - we're planning on using the Mode-C out of the AHARS unit. It's wired to the Skyview and we've got serial port#1 TX (DB37 Pin 4) connected to the TXP pin 24 (RS-232 in). The manual makes it sound like there is another converter needed, but the avionics supplier said it should be wired just like that. If wired like this is correct, do we still configure per pg 10-12 of the Skyview manual "Device in:NONE, Function in:None, Buad: 1200, OutDevice: Dynon" ?
Thanks so much for the assistance.
Finally, WHAT AN AWESOME PRODUCT!!!! I work in the avionics field back in the mid-90s when EFIS systems were limited to high-end jets and Beech Starships. Who'd have ever thought that something like this would be available for folks in the homebuilt industry?
