What GPS source are you using? Is this on the ground or in flight? Pitch and roll should be completely fluid, while the actual position viewpoint is updated as your GPS does. with the SV-GPS-2020 or SV-GPS-250 this is 4-5 times per second. The overall effect should be smooth. If you're on the ground, you might see some GPS "walking" that can be abrupt.
