Skyview with GNS480
Bruno
Hello All
I’m in the process of installing a Garmin GNS480 connected with my Skyview and I was wondering if anyone here may have done the same setup and would have the setup parameter for the Serial port and the Arinc 429 or any trick that may help simplifying the setup???
Bruno
skysailor
I have a GNS480 feeding a Skyview in my Glasair so I can help. Be aware the 480 will only output ADSB+ format on Serial 3 which you need if you want to use it as your ADSB position source. Current 480 firmware is also required. Send me a PM if you like.
