Static system check
  • Thread starter Alan Kritzman(Guest)
  • Start date
A
Guest
I have an appointment to have my static system and transponder certified Friday. I can't see any way to adjust the Dynon so I assume this will be a Go/No Go type of check out. If it does not pass does this mean I have to return the unit to be re-calibrated? Has anyone has a D-10 not pass a static check due to being out of tolerance, or am I worrying about nothing?
The EFIS does have an altitude adjust. You can adjust it +/- 600 ft. There is no adjustment for airspeed however. Every EFIS is calibrated at the factory, and we do not expect that you will need to adjust either setting to pass a check.
