I recently installed a (20-40 amp)stby alternator and wired the b-lead to my existing ampmeter shunt used for the D-180/Plane Power 60A alternator. The shunt is located so it reads the current in/out of the battery. When I turn the main alternaotr off the ampmeter shows about -8 amps (as I would excpect) but when the standy by alternator kicks on the amp meter doesn’t change. Still shows negative amps even though the load is well within the capacity of the stby alt. Should I have installed a 2nd (40amp)shunt for the stby alternator? If so, will the D-180 accept two different current imputs? Thanks, Steve
