My Dynon Skyview HDX was working fine and I have not made any changes to the software or wiring but the Audio Warning/caution volume suddenly decreased so that I can only hear the warnings when the Engine is stopped. The volume is low on both P1 and P2 Headset Jacks and with different Headsets. I have checked that the connections between the Display unit, AV-5000 and the PM3000 Intercom are tight. There is a Mute on Receive function on the PM3000 Intercom Unit but turning this off and on makes no difference.
In the Dynon Setup the volume for the Alerts is set to 100% and if I reduce this value the volume does reduce in the Headset so the control is functioning but the overall volume is too low. Can anyone suggest a most probable cause or, better still a fix.
Thanks in advance
Thanks in advance
