On the same topic, at what rate are readings from the sensors updated? Are all the sensors sampled at 64Hz?
I guess what I'm inarticulately asking is if each of the values (hdg, pitch, etc.) are changing at a constant rate, will the change be reflected in every line in the stream, or will the same value be repeated for a few lines, then updated when the sensor is resampled...?
