chriscalandro
- Joined
- Jul 24, 2020
- Messages
- 166
Ok I’ll bite one more time.
I can type random numbers into an online calculator too to make a single ohm be a tiny change. I can also type a random number into the same calculation to make a single ohm a huge change.
At 12v, a 160ohm resistor measured on the other end is 12v. A 10000000kohm resistor measured on the other end is 12v.
Connecting an output to an input as per the drawing the above poster provided does NOT create a voltage divider.
If I’m going to create my own amp to control a flight control I’m going to make sure it’s correct. So far, nothing you have said here is correct. Again, I’ll go ahead and get the info from someone who has the REAL data I need.
