SV-EMS-220 and the UL350iS Engine
zbuilder750
Ionia, Michigan
I’m working on a Zenith CH 750 build with a UL350iS engine. We’re working with the older SkyView model (specific component: SV-EMS-220) and Im having trouble finding an example of engine sensor and transducer installation configuration for the UL350iS engine. Has anyone installed the Dynon SkyView system with this engine before? What parameters did you use? This is my first home build and I joined later in the process. I have aviation experience, just not in this realm. Really, any guidance in general with regard to SkyView installation would be appreciated.
I think our support team has a configuration worked out for this. Give them a should (contact info in our signature). To use the ECU output (if it has one), you'd need the SV-EMS-221, which support CANBUS output. But even without that, you should be able to measure many parameters with conventional sensors. Check with our support team to be sure though.
pacecapt
Pace, Florida
I fly a Zenith Cruzer with a UL350is and a Dynon HDX system with an EMS 220. I can email you my EMS settings if you would like them.
