Hi,
I have two questions regarding grounds on D37:
- I get RPM information directly from the magnetometers. And the mag documentation wiring diagram shows a connection to "tach" instrument ground. Then I used two grounds from D37 (one for the left mag and one for the right). Here is my question: can I take any ground from D37?
- I used ground pin that was supposed to go on manifold pressure sensor: can ground pins be switched? I guess they all connect to the EMS ground that is supposed to be the same ground.
Thank you for your answer
Clotilde
Clotilde
