I am trying to update skyview to ver.14.2 and the map with av_data and ob_data from Pocketfms. I have done this a number of times with no problem.
I have all files (1 .duc and 2 .dup) in the root directory of the stick in the USB port of Skyview
Now I enter Setup>System Setup and the first item I get is "Update to ver. 14.2 system software". From there my only options are "BACK" and "EXIT", so I am unable to update
Then the following item in the System Setup Menu is "LOAD" from where I always updated the maps.
And, although both av_data and ob_data are on the stick, they don't appear on the right hand side of the screen.
I can't update the maps either.
What can I do ?
Thank you
What can I do ?
Thank you
