System Event 3
birddog486
I plugged in a USB drive while my HDX was booting today and a few minutes later I noticed the screen had a system event 3 message. Did I cause that plugging in the drive during the bootup or is there a problem? This is the first time I've seen this in a year of running the system.
I have two screens connected but this was only showing on one.
I love aviation!
Similar happened to me today. Did the usual monthly DB updates, which auto-sync'd to the other screen, then noticed after the sync finished (seemed like it did the sync twice but wasn't paying enough attention), looked over at EFIS 2 to see a black screen with random colors scattered about the screen. It then rebooted and came up with the System Event 3 error and a request to send the error logging, which I did. Will update when I find out what Dynon thinks the problem might be (if there is one). Only 5ish flight hours on new HDX1100 that replaced my SV1000T screens a month or so ago.
Pro-tip: Do a screen shot of the System Event 3 error screen (requires USB drive) in case you forget the URL to which they want the problem reported and logging loaded.
RV8JD
Posts #2 & #3 of this thread may help:
I love aviation!
My problem ended up being an issue with the FAA database update. When I went to fly last week, the radio could not read the DB. I had to install last months update to get going again. After flying, I downloaded the update again and it worked fine. I suspect I had not "safely" ejected the USB drive on the previous attempt.
