piersherbert
Please could someone explain how the system turns on. The shut down and auto reversion to backup battery (air and ground modes) are clearly explained in the manual. However I am unclear about the start up procedure.
Does the system start automatically when it detects aircraft bus voltage or do you have to press a button to start it. Once started can you change from aircraft bus to backup battery power even while the aircraft bus remains powered? Can you start it on the backup battery even when the aircraft bus is not powered?
