I've noticed that this topic has been discussed for the Rotax engine, but not the Jabiru.
Scenario: Jabiru 3300: Flight Deck Dk180; Pulse/Revolution values are set @ 6; tach wired to alternator with 1 amp fuse; Problem fluctuating tach readings on taxi testing.
Readings: At idle 2000+/- RPM -- hand held tack shows 1050+/- 10
" As I add throttle RPM drops to 1600 then
" Slowly adding more power tach reading comes up then drops until it reaches full throttle and reads 2300 (static should be 2800).
Has anyone had this problem? If so, how did you solve it? Any and all help will be greatly appreciated!
Thanks,
Mack Kreizenbeck
601XL N990MK
Thanks,
Mack Kreizenbeck
601XL N990MK
