It's been a while since I posted and mostly it's because a lot of things have happened. I got my plane painted, which took a little longer than projected, and I had some weather issues here in Ohio to deal with before coming up with a final word on the servo fix. Final word.... the fix Dynon came up with seems to have worked out. Pitch sensitivity set at 7 works for me. Altitude varies +- 20 feet in smooth air, +- about 40 feet in rough air. Roll servo sensitivity set at 5 results in no 'wing wag' and does a slightly more stable lateral control in TRK or NAV. When flying next to Jon Thocker with his Dynon autopilot in HDG or TRK and Altitude hold, we seem to parallel courses better in NAV or TRK and altitude variations, which are pronounced in loose formation are about 15 feet - looks worse next to somebody than it really is. I'd say eliminating the slop from the torque shear screw, which is what the fix on the early servos did, made the autopilot an acceptable performer. And the AP74 is what makes it exceptional. Being able to dial in your HDG/TRK or an altitude with the twist of a knob that is depicted on your EFIS, and then being able to select a mode with the push of a dedicated button is what makes this system very user friendly. I look forward to future products from Dynon and appreciate their upgrade policy. We all like to tinker with our finished airplanes. I also appreciate their support, especially for Mike and Lawrence, and feel completely comfortable with their products.
Scott
RV-8 Fastback, painted and flying....
Scott
