Hi Dynon Official
With a bit more research, I believe the Flarm protocol is more suited to use in outputting traffic information from PowerFlarm to a Skyview screen.
It certainly provides a lot more info and the traffic info, azimuth in particular is a lot more accurate.
I believe Skyview already supports a version of the Flarm protocol?
Version 7 of the Flarm protocol added the ability to output non-directional targets such as a mode C transponder in the $PFLAU sentence.
The non-directional nature of the target is unambiguous in the sentence.
I understand the display issue for non-directional targets on both the PFD and MAP screens, but I would suggest and enhancement similar in logic to when a target is behind the aircraft and only the word "TRAFFIC" is displayed on the PFD with no traffic icons
If a non-directional target is present in the $PFLAU sentence along with distance and altitude info, I would modify the word TRAFFIC on the PFD and MAP screens to include distance and altitude info. For example, for a non-direction target 4miles distant at +300ft, I would display "TRAFFIC 4m +3". Note that only one non-direction target needs to be handled, only the nearest one is output.
Target icons would only be shown for targets containing azimuth information, same logic as now.
The Flarm protocol also contains the notion of 3 threat levels based on time to collision. It would be icing on the cake to annunciate these individually and/or display these on the screen (maybe a color change) if not done already
The argument behind choosing PowerFlarm is not because of a gliding application. It covers both Flarm, ADSB and Mode C targets without the priority issue that skyview has for multiple target type interfaces. The importance of Mode C targets is that fitment of ADSB is not mandated for GA aircraft, but a lot of GA aircraft do have transponders fitted. It is less useful in a busy circuit but could be a life saver whilst cross country.
Doug
