chriscalandro
- Joined
- Jul 24, 2020
- Messages
- 59
Ok I’m stumped.
New install on a Glasair 3, trim via a Linear Actuator rated at 3 amps (so no trim amp)
Nothing out of control panel.
I disconnect the motor and put a meter on it while commanding the motor via the panel, no voltage observed at the motor.
Pull the pins from the connector and touch motor power and ground to the motor and it works normally. It’s powered through a vertical power breaker and when I look the motor is pulling 1.5 amps. No problem there.
Put it all back, nothing.
Pin 2 - GND
Pin 9 - MTR Pwr
Pin 7 - MTR 1 A
Pin 8 - MTR 1 B
Is this bad out of the box? Any ideas?
Pin 2 - GND
Pin 9 - MTR Pwr
Pin 7 - MTR 1 A
Pin 8 - MTR 1 B
