Hi All
I have resolved the issue with Savvyanalysis errors.
The date-time field format was wrong causing the parser to fail.
Here is a summary
If you save the user log csv file to excel, it will convert many of the fields to what it thinks is an appropiate format, including the date time field. When resaved as a csv file, it will save the fields in the new format. Although leading pluses are removed from many fields, Savvyanalysis doesnt seem to mind but the date-time field has to be correct.
To overcome this either
Import the csv file to excel using the import feature, taking care to mark every column as “Text”
or
If the damage is already done, reformat the date time column with a custom format “yyyy-mm-dd hh:mm:ss”
then save. The seconds part will all be zero if the file was saved incorrectly, but it doesn’t seem to bother Savvyanalysis which probably uses the system timestamp for the timeline.
Doug
