UL Power engine fuel consumption
GWMotley
Experimental aircraft fan
Colorado
There are two output leads from their ECU which can provide information about fuel consumption based on duty output or pulses per second from the injectors. That is 100% duty equals 48 liters per hour or 170pulses per second equals 48 liters per hour. Can either of the outputs be used by Dynon to provide fuel flow information on the display?
SkyView does not currently have the ability to use duty cycle as a fuel flow input.
