UMA 1B3 Oil Temp Probe
dodsond
Simple question, please help!
Is there anyone out there using a D-120 with a Type 10 probe for oil temperature?  This would be a UMA 1B3.
How is it working?
More complicated question.
How is it connected, and what do you have it installed on?
dodsond
This is a follow up on my previous post. It appears I may be the only person on this forum with the UMA 1B3 probe. There was a coding issue in the D-120 with this probe, but Dynon has now fixed it.
This 2-wire probe fixed my erratic oil temperature readings I had with the 1 wire standard probe. I highly recommend it. I had UMA make mine with non-standard length leads and had them use shielded wire. It makes for a very stout set of leads and simplified my installation.
Doug
That's fantastic, you finally got it sorted. Now you can enjoy the SV's & flying without that issue 'bugging' you. ;D
