Unused wires on 37 pin connector
hornet2008
Mudgee NSW Australia
Is it OK to remove the unused wires from the 37 pin connector? I'm sure I have read somewhere you can but can,t find the reference now. I have about 15 unused pins.
Thanks Peter
If you've determined that you'll never use those pins, then yes, feel free to remove any wire from the EMS D37F connector. Note that it's a bit tricky to do so with the big heat-shrink over the bundle - you may have to cut off the heat shrink.
Thanks Peter
