UpDate V 14.0.7.3621
B
boblid
Guest
Neither of my units is effected by serial # or hardware version and have been working with no problems. Should I update to the newest version at this time? Or should I wait until the final update version is posted?
If you're outside of the serial number range, no need to use the public test versions unless you have an SV-GPS-2020 that you need to install and are still on version 13.
Tigermoth
If you're currently using V13.03 and a 250 GPS don't you need to upgrade to V14.0+ in order to modify the transponder and resume getting ADSB traffic?
As explained in other postings, Yes.
Tigermoth
This is the statement from Dynon I found confusing.
Apologies for your confusion.
Attempting to clarify, if you have an SV-GPS-2020, version of v14.0.x.xxxx firmware (or later) is required as the SV-GPS-2020 does not function in earlier versions of SkyView firmware.
