USB Drives in panel, no longer reading? The others in the back of the panel are reading.
Brent Dana
Anyone know if there is something I accidentally changed in setup or during an update. I always could load the latest update from the front USB Dives and the ones behind the panel had the original setup information in them.
Now I have to remove the original drives from under the panel, use those to do my monthly update, then reinsert the original setup USB'S back in those spots in the back of the panel. Pain in the BUTT
The panel USB should be just a USB extension cable. You may be able to take the extension connection behind the panel and put in a different USB port. That should test either the extension or the port.
I tried the full formation original flash drives with negative result. still unable to read drive. whats next?
Make sure you aren't using the USB plug that's built into the harness. It's no longer supported. If not, you probably have a bad extension cable or plug.
Some drives won’t read at power up but will if you pull them out and put them in again while it’s powered up.
Try that.
I don't know exactly which update killed it, but it stopped working several years ago.
