User Question on use of VNAV to Runway
HEB1022
Does anyone know if you can set IAS while using VNAV approach? I haven't really tried doing it yet, but wanted to see if anyone else has tried that...
Thanks in Advance,
Harry
Marc_J._Zeitlin
Tehachapi, CA 93561
No. When you're in VNAV, you're following a glideslope, and the only control the A/P has is the pitch control. YOU use the throttle to control IAS. If we had autothrottle...
Brent Dana
There is a setting in (the auto pilot setup) that will allow you to change the decent rate % percentage on the vertical nav to match the the decent rate of the approach, this will give you the calculated decent rate, so that you can manually adjust the vertical speed decent to match.
But speed is your responsibility I am sure.
