User waypoint creator
erichitec
Good night people!
i have some problem with the creator utility of user waypoint
when i press "export" a pront windows open and there is a error on windows, closing de app
i use windows 7 and already try to run the program on compatibility mode(win XP and Vista SP 1,2 and 3)
thanks for your help!
CAVOK away!
erichitec
good night trev
can you send me the link to download?
i seach on the wiki but only find the 3,0 version on "user wapoint" page
thanks a lot!
The version on http://wiki.dynonavionics.com/SkyView_User_Waypoints is the latest and is known to work correctly with 3.1.
erichitec
good day
i still can't make the .dup file using this tool
there is a print of the computer error:
Uploaded with ImageShack.us
Translation of the error: a problem make the program don't work propely.Windows will now close this program and look for a solution
Thanks a lot
erichitec
Can i send the file .KML to you in a e-mail and you send me back in .DUP file?
thanks a lot
erichitec
Can anybody then have this program working make the conversion to me?
thks a lot
If you send it to support at dynonavionics dot com, we'll see what we can do. Include a link to this thread.
erichitec
http://www.2shared.com/file/CbXXTmil/Dynon.html
there is the KML file
~thanks a lot
So that file has a bunch of waypoints, tracks, and other data, but they are not not in the correct Google Earth object types or locations for the Dynon USR waytpoint creation tool to be able to recognize and convert them. Per http://wiki.dynonavionics.com/SkyView_User_Waypoints, you first need to organize your waypoints as placemarks under a folder called Dynon in your My Places folder.
Quick update - I took the waypoints in that file and put them in a Dynon folder and exported them. It actually broke our conversion tool since it had so many waypoints in it. Anyway, the program on the wiki should be updated shortly so that it can handle cases like this.
In the meantime, unzip this file and load it to your SkyView display. It should give you most of what you're looking for.
agnaldocardoso
I am also having this problem, but with a large number of more than 2000 waypoints. When I try with a few waypoints, thats work.
I wonder what the maximum number of waypoints that the skyview support?
Thank's
Right now, the program fails after 1000ish waypoints. There should be a new version up at http://wiki.dynonavionics.com/SkyView_User_Waypoints (check for the date to determine when it goes live) that will handle up to 20,000.
Bruno
Geez, there must be an easier way to create waypoints than this don't you think ? It seem to be a lot of work to create a waypoint..
Will the Skyview  be able someday ( Maybe it is already, ?? ) to load a waypint as we overfly it by just pressing a button like most GPS do??
Thank you
Bruno
