porterjames
- Joined
- Sep 26, 2016
- Messages
- 57
My Dynon autopilot maintains altitude within plus or minus 20 feet. The cycle is up 20 feet and then down 20 feet. Each "up" cycle includes a loss of airspeed and RPM and a gain of airspeed and RPM going down. In very smooth air it isn't too noticeable but in turbulent air the changes in attitude and airspeed are much greater.
Quite by accident I discovered that using the "IAS" mode works great for use in either smooth or turbulent air in maintaining cruse altitude/pitch.
Once at cruise altitude set the altitude bug well above or below your desired altitude. Then select "IAS" just as you would if you wanted to climb or descend. Then set the airspeed bug to whatever your airplane will normally cruise at. Set your power at whatever you normally cruise at and then adjust the airspeed bug or power to maintain that altitude. Even in turbulence I was rarely more than within 200 feet of my desired altitude. Primarily due to me not paying attention over a 10 or 15 minute period. The gains or losses are small and mommetary. Most of the time altitude was within plus or minus 50 feet. The airspeed is maintained very accurately , much more so than during the plus or minus 20 feet using altitude hold.
The reason to set the altitude bug well above or below your desired cruise altitude is that if you ever intercept it during the ups or downs the autopilot will capture it and cancel the "IAS" mode and go to altitude hold instead.
Obviously you can still use the "NAV", "TRACK", or "Heading" mode in addition.
Something I wasn't able to determine is if this method results in a faster airspeed in cruise. I was more concerned about getting to my destination so I didn't do any comparison runs.
