Verns Auto Trim with Dual Displays
sshae
Not sure if this is a question for Vern, Dynon, or both..
I am installing Verns M-PWR-2AT controller for auto trim.  His documentation indicates connecting a serial port TX wire to pin 14 of his controller.
I have 2 displays, so my question is do I use a single wire from one of the displays, or should I connect the two TX wires in parallel and then to pin 14 as Dynon would indicate for most of its own accessories?
Thanks - Steve
vlittle
Hi Steve, I sent you an email. Also, Dynon's advice on this is correct, just hook it up with paralleled serial outputs.
Cheers, Vern
