Vertical Power for GPS 175?
cjohngraham
I have a SV/HDX system in my RV-7A and am installing a GPS 175. The GPS 175 installation manual says the GPS 175 can't share a circuit breaker and should be powered from an avionics or essential bus. My plane uses a Vertical Power VP-X Sport electronic CB system to route power to its various systems and components. Has anyone used VP to power the GPS 175, and if so, any tips?
What I do is just select any 5amp circuit & then label it as Garmin 175 & allocate it to an avionics switch (you can have many other avionics allocated to it too) & you’re good to go.😉
Biggiesauls
NE Texas
Did same. Separate circuit for 175 and G5. Put on Avionics "switch" of VPX.
