vision micro fuel probe to work in skywiew
ralphp
i have a glassair 3 with vision micro fuel probes, I bought Princeton frequency to voltage converters and I'm still not having any luck setting them up, has anyone else ran into this problem or know how to help me, respond or email me at rvpotter2@yahoo.com
skysailor
I have a Glasair Super 2 with the same probe and also the Princeton converters which work fine. I can be of help. One of the bigger things is the converter has to be calibrated before the Dynon is. Use the single set point method. Then calibrate the Dynon normally. Let me know if you need more help. I have probes in both the wing and fuselage tanks.
Skysailor
Can you advise exactly what p/n the converters are & where to order them please ?
skysailor
I can do that Jake. I just called Todd at Princeton Electronics (although email contact is easier) and ordered them. Contact info for them is: 616-243-8800 todd@princeton-electronics.com The converter you want for the Vision Microsystems probe is the CP-10A. The key is to make sure it is set to single set point mode prior to calibration and to use the correct sensor setting in the Skyview. It can be ordered in single set point mode. I can provide more details if you need them. Princeton is very responsive to emails in a timely manner.
