Volt meter Stopped showning value
bmiller269
My Skyview classic has been up and working fine but, I had a longer than normal start (cranking) the other day. After the skyview came up. I noticed that I had no Voltage displayed. The Amps is showing and working fine. So I unplugged and tested pin 1 on both displays and have a 12.03 volts. Checked the mapping and it's the first one there. What else should I look at?
The voltage is read from a pin that goes to the EMS module, not the SkyView display's own input voltage. So probably that wire - which would be on the EMS DB37 pin connector - is the first place to look.
Seems to me that there may sometimes be a 1A fuse on that line the same as on the AMP shunt. Page 7-62 of the installation manual.
bmiller269
Hope to get to the airport tonight and do some more digging. I was looking in wrong place. Will check the ems and move forward from there. Thanks for Help
