volts reading zero
WrightsRV7
Everything seems fine with the system after boot up and configuring the EMS accept one thing, volts is reading zero. Amp draw reading correct and in certain network status windows, a voltage is given, but not on display in the virtual gauge. Am I missing something in the set-up? The pin is selected for 1 and the ranges are normal. How can I be fully powered up, reading amps, displaying all instrument values correct, and not get a voltage? Just seems very odd.
Cheers, Mike :-/
You actually need to have the EMS module's pin 1 hooked up to voltage somewhere. It's not the SkyView display voltage that gets read by that widget.
